Hopefully a simple question.
We want to use a HP 460cb Wireless printer on a small wireless network which has been set up based on WPA2. The printer optopns are open, WEP, WPA-PSK. There is no WPA2 option. The printer uses a Compact Flash Wireless card.
I'm assuming that the lack of a WPA2 choice means it probably doesn't support WPA2.
Any comments? Anybody able to confirm?
(and yes, I cannot get the printer working on this wireless network).
Thanks,
