Does anyone know whether some wireless network cards will not connect to a wireless network with WPA encrytion? I have a USB D-Link wireless network adaptor and I'm trying to connect to a friend's wireless network that has WPA encryption. It finds the SSID of the network ok, when trying to connect it prompts for the encryption key but it it just goes through a loop of aquiring the network address but can't find it. After a while it says its connected but with limited or no connectivity. I can't find another PC on the network and it is not assigned the correct IP Address that is in the range of the network. There is no Internet access either. My friend won't remove the WPA encryption so I wanted to see there are problems with having WPA encryption on the wireless network and certain wireless network cards (even USB) in the first place. Also, if I connect via the ethernet cable to the wireless router it connects ok and there is internet access.
- posted
16 years ago
