I haven't been able to correct the problem. As I mentioned above, the
WPA security setting seems to work for a while (couple of hours) and
then starts to drop off and on every 3 or 4 seconds. I guess I'll go
back to 128 bit WEP unless somebody has a solution. I don't use my
wireless computer that often and I understand WEP security isn't really
that bad especially for infrequent home use.
