I'm using a Netgear WGR614 Router (on xp machine) with a WG111 wireless
USB adapter (on 98se machine). I have been using WEP security for weeks
with no problems and no disconnects. I wanted to start using WPA
security. It works fine for a few hours and then I get on-off-on-off
(green-red-green-red) connections. The only way I've been able to fix
it is to enter new a passphrase in the router and copy the numbers into
the wireless adapter. I know that the passphrase has a "key life timer"
but isn't that supposed to be an automatic change? I'm not even sure if
that's the problem. Is there something I'm doing wrong? There must be a
way to keep the WPA connection alive for more than a few hours. Should
I just go back to WEP? Please help. Thanks.
