I have a WMP54G PCI card in my desktop PC. A while back, while doing some fixes, I knocked the antenna off the card. It appears to be attached by a small plug which is seated in a hole on the card, slotting over a small piece of wire. There doesn't appear be any threading indicating that the antenna originally screwed, or any bright metal indicating anything actually broke. Yet the antenna no longer seats correctly in the hole, and the signal is poorer. Any ideas how to repair it, or replace the antenna, without having to fork out for a new card?
Thanks,
P.
