I have a very strange problem with my WLAN-Router (Sinus 1054 DSL). So far I only used it with LAN, which is working just fine. I just occasionally turned on the WLan when I had visitors. Then the problem occured: The network was visible (and strong) but it was not possible to connect (it did not give the laptop an IP address). This happend with a number of notebooks under both linux and windows. All of those visitors were computer geeks and checked the configuration of the router, but everything was fine (different configurations were tried (with, without encryption; with, without MAC-Filter), but nothing worked.)
Now the strange thing happens: With one of these friends it suddenly worked the next morning: I did not change the configuration of the router nor did my friend change his settings. With another friend it worked after changing the channel.
This kind of gives me the idea that maybe the WLan has some kind of weird problem with another WLan, since that could explain the above phenomenon. Anyway I never really tried to solve the problem, since I did not have a laptop to use the WLAN for, until last week. Now the same problem happens again, but switching the channel does not work this time. Also the configuration of the notebook is fine, because I can log on to another (someones :-)) network, which is much weaker.
I have absolutely no idea what else I could try - also it does not sound like a hardware problem, because occasionally it does work. I am also fairly certain that the configuration of the router is fine, since I had independently different people (all of whom are computer experts) check it because of the problem and noone could find anything wrong.
I would greatly appreciate any suggestions.
Best, moepmoep
