Hi folks, i really do hope somebody here can shed some light on this.
ok - i have problems with two totally different systems in different locations but the problems are the same.
system 1 - xp pro pc with wireless adsl router connected by ethernet. xp pro pc 20 feet away connected via wireless. all works perfectly well 'without' WEP or WPA enabled. as soon as i try enabling any sort of security on the wireless it refuses to connect to the network.
system 2 - xp home dell lappy connected to wireless adsl router via wireless 'with' WEP enabled. works perfect. xp pro pc 20 feet away refuses to connect to network with WEP enabled. if i disable WEP on the router it all works perfect.
before routers were bought (both different makes) both systems was connected to coresponding computers through wireless cards/dongles 'with' WEP enabled no problems.
that suggests that maybe the routers are the problem, but - how can the router be the problem because system 2 connects ok to the dell lappy with WEP
its kinda doing my head in and no matter where i look i've not been able to find any answers on the net.
please help me somebody
TIA
Chris
