I live in the Balkans and have an ISP that uses PPPoE.
I would like to set it up to use my wireless router- DI-524. I have connected the LAN cable directly from the ISP's modem to the WAN port on my router. Then, i set up the router to use PPPoE and put in the username/password. I can wirelessly connect to the router but am not able to "connect" to the internet via this wireless connection. I mean, I click on the ISP icon and click "connect" and it says it is connecting but doesn't. But, when I reconnect the LAN cable to my comp, i can connect tot he internet right away.
So, is it possible to connect WAN miniport PPPoE wirelessly through a wireless router or not. If so, any ideas on what I am doing wrong?
Thank you,
Karl
