| I love it. Mobile phone attracts lightning? Maybe if it had a tall | antenna attached but the tiny cell phone antenna isn't going to do | much.
I heard a theory long ago that RF in the mid UHF to upper EHF range had a certain ionizing effect that could start a leader under conditions where the risk was already substantially high. This _may_ be the same condition where hair stands on end, but I didn't hear the specifics like that with this theory. The impression I got from it was that this is when lightning almost certainly will be striking somewhere nearby very soon and that the RF ionization introduces a better path or makes a leader for the full return stroke to find.
I've not tested the theory. I have had what I think was one opportunity to do so, but elected to turn radios off and leave. Lightning did hit near that location about 10 minutes later (not seconds, but minutes, even though I was seeing substantial charge buildup producing half inch arcs from the inside connector of the coax leading to the roof antenna, and the car frame. Could I have brought on an earlier hit right at me or my car had I transmitted on UHF? It was "only" 446 MHz. But I did not feel like trying it. OTOH, I had about 35 watts of power, which is well less than what the cell phones and cordless phones have. With 35 watts you do NOT want to be touching the antenna when transmitting, just to give an idea.
Hey, I'm still here (to the dismay of many usenetians).
|>When a person is hit by lightning, the high resistance of human skin |>causes the lightning charge to flow over the body - often known as an |>'external flashover'. | | High resistance? High resistance PREVENTS conduction. Electricity | follows the path of least resistance, not most resistance. The | observed flashover phenomenon is probably correct, but the explanation | seems a bit lacking.
His explanation was certainly incomplete. The working resistance often used to calculate human body current is 1000 ohms, when dry. Given a high enough voltage, however, an arc can form over the skin surface. Once that happens, the new ionized path is sufficiently low a resistance to pass the full current, but still has sufficient voltage drop to dissipate a substantial amount of power, which measured across a time interval is the energy produces a temperature rise of tens of thousands of degrees (fahrenheit or centigrade? ... who cares).
|>But some of the current can flow through the body. The more that flows |>through, the more internal damage it causes. | | Rubbish. Go find an ohms-guesser. Pick an animal, any animal. I | dead chicken will do. Peel off some skin and measure the resistance. | Then, shove the ohms guesser probes into the chicken and measure the | resistance. The skin is very high resistance while the body, which is | loaded with conductive fluids, is much less. If anything, the skin is | almost an insulator, not a conductor. Since electricity (lightning = | DC) follows the path of least resistance, most of the current will go | through the body, rather than though the skin.
Depends on the level of sweatiness, salt on the surface, rain mixed in with it, wet sweaty clothing, etc.
If you think skin is an insulator, I invite you to go swimming with an electric eel. Or maybe just swim in a pool with broken lights running at a "mere" 120 volts that were never even UL-listed for pool use in the first place. The surface of dry skin makes a poor contact. But I would not characterize it as an insulator at all. Of course wetness also makes a broad parallel path through the skin, too. But then, there is a good chance if you are out in a thunderstorm that you are not dry.
| What can I say? I'm right and the rest of the world is wrong.
One of the universal truths for everyone.
