Posted by Bob on May 29, 2008, 10:35 am
I'm about to depart the hot southwest desert for the mountains in our
travel trailer. Last year the WIFI service was margina (mainly low
signal levels inside the trailer)l, so this year I've installed an
outside directional antenna on a rotor. Since both my wife and I want
to use computers at the same time, I created an in trailer network.
It consists of: from the house Qwest(Actionteck) DSL modem to a
Linksys WET54g bridge(located in the trailer) (wired) to a Linksys 4
port hub. From the hub I connect (wired) to my computer. Also,
(wired) to a Linksys WAP54g access point. Connecting to the WAP54g
(wireless) is a WMB54g music bridge to the trailer audio system. When
feeding audio from my computer the system works OK.
When I connected the laptop (wireless) to the WAP54g, I get a good
signal level connection, however when browsing the WEB, the screens
are somewhat jumbled or I get a "can't display that page" error.
Connecting directly (wireless) to the Qwest modem, things are OK.
Am I trying to do something that isn't feaseable?
Thanks
FYI, the coax feeding the WET54G is about 8 inches - I mounted the
WET54g just inside the roof and the antenna is just outside the roof.
Besides, the signal level is shown as 100% on both WIFI sources.
(Probably not quite the same, but certainly adaquate.)
| Similar Threads | Posted |
| Nedwbie question about wireless network | November 23, 2005, 10:33 pm |
| Wireless Network speed question... | December 6, 2007, 3:24 pm |
| Long distance wireless network setup question | July 21, 2007, 6:50 pm |
| newbie question: wireless router on a local network | January 19, 2008, 2:41 pm |
| Question on major change in Transfer speeds over wireless network. | November 19, 2006, 9:32 pm |
| wireless to wireless network question | May 29, 2008, 10:35 am |
| Newbie question: hacker access to Linksys WRT54G wireless network | January 4, 2005, 6:31 am |
| newbie Question: Setting up Ad-hoc wireless network and share files/folder? | January 16, 2006, 11:52 pm |
| Network Products Question | July 13, 2005, 2:52 am |
| network Config Question | June 17, 2006, 9:54 pm |
| newby network question | December 27, 2007, 11:27 pm |
| Mixed mode network question | January 2, 2005, 10:45 am |
| 802.11G health issue and home network cabling question | September 25, 2006, 8:32 pm |
| Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good you are, | April 22, 2005, 7:19 pm |
| Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good you are, | May 1, 2005, 2:40 pm |
