trying to setup a netgear wg602v3, & the setup disk is lost! any ideas where i can download a fresh copy?
or good simple details on setup
Roy
Roy
You don't need the CD-ROM. Reset the modem/router using the proper button in the back (keep it pressed for 30 seconds). Then hook up the phone cable (ADSL) and connect your PC/laptop to the modem/router (no wireless during set up). Open a browser page and type the following in the address bar:
http://192.168.1.1/ and enter, user is admin and password is admin. Follow the instructions.
If you are connection to a LAN, just hook it up and it will work even wirelessly, without going into the configuration panel. If you want to protect the access with a password (WEP or WAP), go to:
http://192.168.1.1/ and look for the wireless setup and follow the instructions.
Good luck and happy surfing!
Steff
royc wrote:
its a access point, not a modem/router, i had tried that.
netgear say it installs from gear cd, but my customer has lost the disk.
roy
Are you trying to connect it to ADSL or LAN? It won't work with ADSL. For a LAN connection, it'd be a straight forward operation: hook it up and connect.
Royc wrote:
