We all know wireless even with all the WEP and WPA security bells and whistles turned on is not secure - it can usually be broken within a few hours.
My company has had a commercial wireless security product used in offices and company settings that works great, but is too expensive of a solution for the private individual.
A friend of mine and myself took the task on to develop a wireless security client that would meet the following qualifications:
- 100% unbreakable encryption 2. Would work from any wireless network in the world, as long as it was connected to the Internet 3. Cheap enough that the millions of home and public wireless users would be able to use it 4. Wouldn't require any additional hardware 5. No security knowledge would be required - download, install, click "secure"
After two months of hard work we've got it all put together. We're looking for users that would like to test and use the security for FREE until we go "live".
The security works 100% during our testing period, there are no features disabled during testing - you get the real deal for FREE.
After we go live with the security client we will pay you $5 per month for every customer that you send our way. You can see how this can quickly add up - 20 referrals is $100 per month. By introducing the wireless security solution to your friends and people you meet at public wifi spots you can easily generate some serious residual income.
To sign up or read more about it, go to:
Thanks!
