Redoing the settings on a dlink di-714p+ and wondering if it seems correct or if I've missed any holes.
DI-714P+ Home Network Setup w xp and 98, some airplus some not: dsl always on -enabled 4x mode
-new password
-new ssid, not broadcast
-ch:1
-wep:128 (have a win 98 w. a non wpa supported card on network)
-shared key
-Current Firmware Version: V1.33 Firmware Date: Thu, Jun 17 2004
-syslog enabled
-long preamble
-Blocking WAN Ping -Discard PING from WAN side
-spi mode enabled
-UPnP enabled
-VPN pptp disabled, ipsec disabled
-enabled mac filters to allow only
Not sure about spi, UPnp, or VPN. Also is there any advantage to change DHCP server to static settings, or to change lan address settings? Thanks for any comments.
F.plant
