Theres an option in the DHCP menu of my router IP range start & finish - just specified a range of 2 e.g. 192.168.0.2 to 192.168.0.3 - then statically assigned them to the 2 mac addresses on the network - it seems happy enough, I'm just not sure if it has any other implications, or causes any problems
I understand the part about people sniffing the network and possibly finding the IP start (e.g 192.68.0.x) part Nemo, but if there are only 2 available IP addresses and they are both taken, I dont understand how another addresss can be accepted by the router, sorry if I'm being thick, I'm only just learning about networking.
To clear things up, i was under the impression that if you set an IP range, DHCP could only assign a device an IP address within that range,once all the addresses were assigned, no more devices could log on to the network, hence my network (along with the other precautions I have taken that were listed in my original post) would be secure from intruders.
After enabling WPA and changing the default password and SSID, fiddling with IP (or MAC) addressing provides, at best, only miniscule additional security benefits that aren't worth the hassle.
As others have pointed out, shrinking the pool of addresses handed out by the DHCP server doesn't really restrict the number of IP addresses that can use your network. To do that, you need to alter the subnet masks of the router and other devices. For a two-device network (a router and one computer), you'd use a subnet mask of 255.255.255.252. The next smallest standard subnet (with a continuous range of addresses) you can create is for six devices with a mask of 255.255.255.248.
Yes, you got it wrong. Most routers will serve any clients in their subnet, no matter how they acquired their IP addresses. The router only ignores IP addresses outside its subnet mask, not outside its DHCP address pool.
"Rick Stevens" wrote in news:tcDgh.11783$ snipped-for-privacy@newsfe2-win.ntli.net:
Yes, this is wrong.
The DHCP scope does not define what addresses can be used. That is the job of the subnet mask. DHCP only hands out an available IP address to a device that asks for an IP address.
The router IP of 192.168.0.1 with a subnet mask of 255.255.255.0 defines the subnet that can communicate within itself as 192.168.0.1 thru .254.
Just because the the DHCP server only has 2 IP's in it's scope, it does NOT limit usable IP's, only the IP's it hands out.
As Neil pointed out, is the router SNM is set to 255.255.255.252 instead of 255.255.255.0, then that subnet only has 4 IP's. .0 being the subnet ID, .1 & .2 are usable, & .3 is the broadcast.
You have the rtr, and 2 IP devices, which is 3, so it won't fit in a .252 subnet. The next size subnet is .248. Subnet ID of 0, usable IP's of .1 - .6 and a broadcast of .7.
So there will always be usable IP's that are available in your system. That is why the rtr needs to be locked down with the other features & tools it provides.
I also do see why people use DHCP, maybe because that how it is by default, but on a home network, totally unnecessary. It's not hard to keep track of less than static 10 IP's.
"Rick Stevens" wrote in news:oWOgh.7889$ snipped-for-privacy@newsfe4-gui.ntli.net:
Not being thick. If you don't do computer/technology stuff for work, or as a hobby, or learn it by taking courses, it can be very confusing and seem very complex since there's so many details.
Hopefully you were able to undestand my ramblings, I did have a link to an article about subnetting that for some reason or another, was extremely well written and made everything very clear and easy to understand. It was only 2 or 3 pages. As usual though I can't find the link.
