Wireless router security
Threaded View
Hello,
I need to setup a wireless router. I would like to know if allowing
connectivity by MAC Addresses filtering is secure enough. I dont want
to setup the key for each machine, so I was thinking just to setup all
the MAC address for the wireless devices. Is any problem with it ?
Will it possible to hack the router ?
thanks,
Giovanni
Re: Wireless router security
MAC address filtering is simply a hurdle and lLike most hurdles, it is
just a deterrent.  MAC addresses can be spoofed and when you're not
using your wireless device, a hacker can use the spoofed MAC address
to access your net.  Having said that, it is extremely important that
you enable encryption, preferably WPA (via RADIUS) or WPA-PSK (TKIP or
AES) using a long passphrase that contains letters, numbers and
symbols.  Just my two cents.  Take care.
On 10 Nov 2004 14:29:13 -0800, jjcuzz@hotmail.com (Giovanni) wrote:
>Hello,
>thanks,
>Giovanni
MAC address filtering can be spoofed. In and of itself, it is probably very
secure as those that know how to spoof it are not likely to come along and
hack into your network Nethertheless, I strongly recommend you also enable
encryption as well. That too can be broken, so the next thing you do is
change your key on a regular basis. I personally don't use MAC filtering, I
use 128 bit WEP, and I don't even bother to change it. My neighbor has a
Linksys router with all defaults. The other day I was able to access his
router's config pages because he didn't even change the admin password. I
could have locked him out of his router, but I'm not mean enough to do that.
> Hello,
> thanks,
> Giovanni
Site Timeline
