Hi All,
I have a COMPUSA 54 MBPS wireless broadband router. I didn't have any problems connecting to it till now.
Suddenly the connection on my laptop showed limited / no connectivity. I was not able to connect to the admin opage of the router as well.
When I tried repairing it using the Windows option, it showed that the router is unable to assign an IP to the laptop. So I went ahead and manually configured an IP as 192.168.2.100 (same as the router would have assigned in the usual case) and default gateway as 192.168.2.1. When I did this, I was able to connect to the admin page of the router, but then again it didn't help.
Right now I am connected to my Cable modem directly and its working absolutely fine. So its not the modem thats an issue. Als since the wireless adaptor shows full strength signal and tries to connect to the router I am assuming that the hardware is not an issue. So I tried to upgrade the firmware, but that didn't help too. Here's my ipconfig output when connected to the wireless router. I get the same when I connect to the ethernet cable through the router.:
Windows IP Configuration
Host Name . . . . . . . . . . . . : keethy-kuty Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Unknown IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection Physical:
Media State . . . . . . . . . . . : Media disconnected Description . . . . . . . . . . . : Broadcom 440x 10/100 Integrated Cont roller Physical Address. . . . . . . . . : 00-14-22-AC-01-59
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) PRO/Wireless
2200BG Network Connection Physical Address. . . . . . . . . : 00-16-6F-95-6D-80 Dhcp Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Autoconfiguration IP Address. . . : 169.254.158.198 Subnet Mask . . . . . . . . . . . : 255.255.0.0 Default Gateway . . . . . . . . . :I guess the DHCP has a problem on the router, but what can I do abt. it. Can anyone help?
Thanks, Anand.
