I just installed a wireless router (Trendnet tw 432 brp) and I regularly loosing the connection. At first I though that is was after a certain amount of time, but I think it is perhaps after a certain amount of data transferred. If I only brose internet, it can take up to several hours. If I try to transfer a big file to my other computer, it takes minute before I need to restart the router. The router is configured with WPA PSK AEP, but I had the same problem when no encryption was used.
I was thinking of buying a dlink di 524, but with all the post I have seen on internet, I wonder if it is possible to have a wireless network without having so many problems.
Any suggestions?
Thank you,
Sylvain
