Now with pictures!
Subject
- Posted on
July 14, 2005, 8:24 pm
Hi
I have a Dlink Ethernet router connecter to Windows 2003 server. All
computers could see each other and access the internet.
I have to put an external computer in a shop across the road and have
purchased a Sitecom wireless router and wireless pci card to connect. All
set up and internet connects fine. I cannot however access the server or
even join the domain. Keep getting a message that the domain is not found. I
can connect to the PC's including the server using the ip address but
conversely none of the other computers can now see the wireless networked
pc.
Any thoughts
Regards
cds
Re: wireless router connecting to ethernet router
"News" wrote in message
I
How is the Sitecom wireless router connected to the Dlink Ethernet router?
I'm assuming that you are wanting to use the Sitecom wireless router only as
an access point, since the Dlink is taking care of routing? If so, the
Dlink needs to be fed into one of the Sitecom's LAN ports and not the WAN.
Disable DHCP on the Sitecom as well. (The Dlink is taking care of assigning
IP's.)
I'm using "ZoneCD" (Captive Portal) and doing exactly that here.
Originally, I was only using one router (wireless) but then picked up a
wired router. Using the wireless router as just an AP now.
Sounds like that is how you are setup though since everything can talk out
onto the internet -- but the wired computers can't see the wireless. Is
there an option in the Sitecom wireless router (that you are now using as
just an AP) to "Bridge wireless to wired"? My DLinks have that option and
would behave exactly like you describe if it were disabled.
Hope that is of any help. :/
Cheers,
-E
All
found.
networked
as
assigning
Oh, sorry, after posting realized I should've mentioned that it is a little
different with "ZoneCD" in the loop. Everything connected (wireless) to the
AP feeding from the "ZoneCD" computer is in a different IP block than the
wired stuff going to s wired router. I have the wired router's DHCP giving
192.168.0.x's while the wireless AP is passing 10.10.10.x's (it's DHCP
server is "ZoneCD"). The "bridge" between the two is "ZoneCD".
I played with it before throwing "ZoneCD" in though. Wired router connected
to wireless router (used only as AP). Only one DHCP was needed in this
case. Everything talked to one another..
"cds" wrote in message
NP. Sorry, didn't mean to get OT with "ZoneCD". At first seemed like a
good "model", but then remembered about using different IP blocks for wired
and wireless.
Only thing I can think of is the "wired/wireless bridge" option. I'm sure
others will reply with more helpful info though.
Cheers,
-Eric
Site Timeline
- » Use a wireless router as a repeater for a laptop?
- — Next thread in » Wireless Networking
- » How Does Best Buy Do It
- — Previous thread in » Wireless Networking
- » Things learned about Ubiquiti PoE adapters and devices
- — Newest thread in » Wireless Networking
- — The site's Newest Thread. Posted in » Wireless Networking
