Wireless Networking wireless router as Lan adapter
Subject Author Date
wireless router as Lan adapter jimmie68 07-02-08
Posted by Jeff Liebermann on July 4, 2008, 8:41 pm
On Fri, 4 Jul 2008 10:46:48 -0700 (PDT), jimmie68@gmail.com wrote:
>Building a gain antenna is easy enough, what I was wondering about is
>the losses in the cable. At 2.4Ghz its going to take some really good
>feedline. How do the WIFI people handle this? I would think about
>putting a router very close to the antenna since low loss cable can
>cost bucks a foot.
That depends on how much cable and how much fade margin you have. I
prefer to put the router next to the antenna, but even that requires a
coax "pigtail".
The question is how much additional cable loss you can tolerate before
your signal craps out. There's a really crude test that might offer a
clue. Take a piece of wet cardboard or black IC foam to block half
your panel or dish antenna. That's a 3dB loss. Block off 3/4 of the
panel, and you have a 6dB loss. Crude, but effective. Don't use foil
or metal reflectors for this. You want the blocking device to be an
absorber, not a reflector. That should give you a clue as to how much
loss you can tolerate. Of course, a real coax RF attenuator is the
right way, but if you had one, you probably wouldn't be asking this
question.
Cable loss is easy and comes from a simple chart:
LMR-200 16.9 dB/100ft
LMR-240 12.9 dB/100ft
LMR-400 6.8 dB/100ft
So, if you decide that you can tolerate 3dB of additional cable loss,
that means you can use about 44ft of LMR-400, or 23ft of LMR-240, or
17ft of LMR-200. Lots of pre-cut cables with connectors available:
<http://www.fab-corp.com/home.php?cat=248>
<http://www.fab-corp.com/home.php?cat=249>
What this means is that for fairly short coax runs of perhaps 10ft or
less, don't worry about cable type. Almost anything will work. If a
few dB make a difference, you already have a marginal system anyway
and need to do something else.
Also, I've been quite successful using 75 ohm coax instead of 50 ohm
as in RG-9/u CATV coax. There's a slight mismatch, and two additional
coax adapter are required. The nice part is that it's commonly
available, very cheap, and can be assembled without expensive tools
and crimp connectors. However, don't go cheap on the F connectors.
Use proper piston type tools and "push on" F connectors.
Jeff Liebermann jeffl@cruzio.com
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 http://802.11junk.com
Skype: JeffLiebermann AE6KS 831-336-2558
Similar ThreadsPosted
Wireless Adapter as Router ? September 7, 2007, 2:27 am
Router used as a wireless adapter September 1, 2005, 7:06 am
Can I use a wireless router as PC adapter? January 31, 2008, 10:14 am
wireless router as Lan adapter July 2, 2008, 9:10 am
Wireless Notebook Adapter in a Router? June 6, 2006, 12:33 pm
winxp box with wireless router to win98se box with USB adapter February 16, 2005, 10:20 am
Linksys Wireless Router B to Belkin USB Adapter G March 10, 2005, 8:01 pm
Belkin Modem/Router as a wireless adapter? April 20, 2007, 8:00 pm
Struggles with Wireless-G Linksys USB adapter and 2wire Router October 15, 2006, 4:11 pm
Can't start internal wireless adapter after installing a buffalo adapter August 7, 2007, 6:09 pm
Getting Sprint USB Wireless Network Adapter to work w/ Wireless Router January 13, 2008, 4:37 pm
Any way to use a netgear wireless router as an wireless internet adapter? July 4, 2006, 12:47 am
How to connect to router through adapter March 22, 2006, 4:38 am
Will 802.11b Adapter Work with 802.11g Router? August 1, 2007, 6:59 pm
Will an 802.11b adapter work with a 802.11n router? January 4, 2008, 1:16 pm
