I am using a Packard Bell EasyNote laptop with XP. For some reason, when I checked my Network connections (in Control Panel), the wireless network option has disappeared.
I then checked Device Manager and it is listed as Intel Pro Wireless
2200 BG but there is a problem: This device cannot start. (Code 10).I have uninstalled and re-installed the drivers both from Windows and from the Intel website and re-booted to no avail.
This is what I downloaded from Intel:
One suggestion was to disable wireless in the BIOS then uninstall the drivers in Control Panel, then re-enable the BIOS and install the drivers in Control Panel; however BIOS does not give me this option.
If I uinstall the drivers then reboot, XP automatically installs the wireless drivers again, but you get the "exclaimation mark" indicator in Devices that there is a problem.
Any ideas? Thanks =96 your help is much appreciated.
