Hi wireless,
I have this printer
Appreciate any help \\ info on this :-)
Thanks
Hi wireless,
I have this printer
Thanks
Trying to use multifunction printers from a wireless connection usually means losing anything other than the printing functionality.
What I've done is hang my printer off a desktop and shared that to the network. The printer's full range of features remain usable (on that PC) and everything else on the network can print through it. Works quite well. Even a barebones PC could do this with ease.
-Bill Kearney
printer
You can use buy a wireless print server with the printer, but I have tried these before (two different types) and they were very problematic and didn't work.
What has become available the past few months are printers (not expensive) that have built-in wireless capability. I have an HP printer that cost $88. It is not a multifunction printer (I don't trust those), and works very well and has built-in wireless (WiFi not Bluetooth). It set up on all my PCs just fine, even a Mac laptop. It is not connected by hard-wire to any computer itself - it shows as a printer on the Ethernet wireless (WiFi) in my home.
Consider a plan B.. Wireless printer things usually suck (and won't do multifunction things for diddly), I picked up a used laptop at goodwill with wireless for $50... I not only have the printer on that (so it can be used by anything on the network) but also picked up a 1 Terabyte USB drive and have that on the laptop too, so in essence I have network storage AND a printer on my wireless network, and can use it not only from other laptops/desktops, but my PDA's and Tivo's too....
You can use a wireless print server.
If you want to maintain full functionality then you can use wireless USB, i.e. "
