Wireless print server with parallel port & WPA
Hello,
I'm looking for a wireless print server that has a parallel port and supports WPA-PSK encryption. We have an a colour laser printer without a USB port, and our WLAN is using WPA-PSK.
AXIS, Linksys and a few others do do a product, but only support WEP! With no plans to update their firmware. :(
Can anyone suggest a product ?
Thanks in advance.
Emlynfluff
Thanks Stein, I'm just after a wireless print server, not a complete wireless ADSL router.
LIke this product -
But obviosuly I want one with a parallel port.
Emlynfluff
A quick froogle search yeilds several:
Jerry Park
Thankyou Jerry.
I refined the search for the UK and the dozens of products reduced down to just the 1 ! The Motorola WPS870G would seem to do the job, nicely.
Emlynfluff
wrote in :
I've got a D-Link DI-824VUP+, which supports VPN, PRT Mate printing (both USB and parallel port), WEP, WPA and WPA-PSK.
Stein Arne Storslett
It would indeed, if it actually supported WPA. But it doesn't, despite the specs saying that it does.
See "
" I have been looking for the same type of print server. As someone else pointed out, the DI-824VUP+ would work, but it's more than just a print server.
The only one I was able to find, that really supports WPA, was one from ActionTec,
" Review at: "
" It cost $129, more than the All-In-One product from D-Link.
The less expensive way to go is probably an Ethernet to Parallel Port adapter, connected to a wireless access point.
SMS
