The Ethernet port on my OfficeJet flaked out, so I decided to use a D-Link DP-G321 Print Server that I had, which worked the last time I used it.
I set up the print server with a local IP address of 192.168.0.10. This is also the IP address used when setting up the TCP/IP printer ports.
---------------------------------------- Server Name : PS-5C6FDC Model : DP-G321 IP Address : 192.168.0.10 (Manual)
The print server sees my wireless network just fine during setup when it scans for available networks, and the SSID and key are correct.
One of the printers is set up as follows:
Port Name: IP_192.168.0.10 Printer Name or IP Address: 192.168.0.10 LPR Settings Queue Name: PS-5C6FDC-P3 (which is what is specified by the print server instructions).
Port Name: IP_192.168.0.10 Printer Name or IP Address: 192.168.0.10 LPR Settings Queue Name: PS-5C6FDC-U1 (which is what is specified by the print server instructions).
The printers work fine as long as I'm hard wired in to the print server, but I can't print wirelessly. If I try to print wirelessly, though as soon as I plug the print server back in via wired Ethernet the jobs print from the queue.
I wasn't sure if I had to be within the IP Address range of the router, so I also tried using 192.168.0.110 as the print server address (and the port address for the TCP/IP printer ports), but that didn't work either.
-------------------------------------- The Router is set as follows:
Local IP Address 192.168.1.1 DHCP Server Enabled Start IP Address 192.168.1.100 IP Address Range: 192 .168 .1 .100~149
Subnet Mask is always 255.255.255.0
Anyway, any ideas are appreciated.
