Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Jon Vaughan on April 25, 2005, 11:17 pm
Please log in for more thread options Hi all. Im not 100% sure this is posted in the right place, but I will carry on.. I have a printer hooked up to a belkin wifi print server, all is fine until the paper needs changing, if print jobs are built up, when the paper is replaced the printer wont automattically start printing the next job, often it wil take a power down of the printer or a power down of the printer and the PC and often the old jobs need to be cleared and re sent.. Is this a common printer problem? is it a wifi problem ? If anyone has any ideas, as I have no idea at the moment. Thanks | |||||||||||||||||||
Posted by Duane Arnold on April 26, 2005, 12:22 am
Please log in for more thread options You can call the manufacture's Theh Support. That is what they are there for. Duane :) | |||||||||||||||||||
Posted by MrSmiley on April 26, 2005, 3:36 am
I've experienced this with USB print servers. Seems that most of them allow basic printer functions, nothing like ink levels, diagnostics, etc. Parallel print servers seem to act a little better. Guess it depends on the printer. Rob > Hi all.
until
> > Im not 100% sure this is posted in the right place, but I will carry on.. > > I have a printer hooked up to a belkin wifi print server, all is fine > the paper needs changing, if print jobs are built up, when the paper is
often
> replaced the printer wont automattically start printing the next job, > it wil take a power down of the printer or a power down of the printer and
> the PC and often the old jobs need to be cleared and re sent.. > > Is this a common printer problem? is it a wifi problem ? > > If anyone has any ideas, as I have no idea at the moment. > > Thanks > > | |||||||||||||||||||
| Similar Threads | Posted |
| Can a router w/ print server work as a plain print server? | November 2, 2004, 9:22 pm |
| Problems with US Robotics 5461 wireless print server - "cant create print job" | December 9, 2006, 1:40 pm |
| Print Server vs Print / Scan Server | November 13, 2004, 6:38 pm |
| wireless print server | April 25, 2005, 11:17 pm |
| Wireless Print Server Help | September 13, 2005, 6:00 pm |
| Wireless Print server | November 1, 2007, 7:56 pm |
| wireless "b" print server on G network | November 23, 2005, 4:46 pm |
| wireless print server two-sided | November 30, 2005, 9:59 am |
| Does any wireless print server work? | January 26, 2006, 5:26 am |
| Belkin Wireless Print Server | April 12, 2006, 2:41 am |
| Wireless print server question. | May 25, 2006, 5:17 pm |
| Wireless print server problems | May 25, 2006, 5:26 pm |
| Wireless print server question | August 4, 2007, 4:27 pm |
| Wireless print server (Centronics) recommendation | August 13, 2005, 6:56 am |
| Wireless print server with parallel port & WPA | September 5, 2005, 1:47 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> on..
> Thanks
