Hi Folks,
I am looking for any assistance with the following problem.
I have a Toshiba Laptop, Centrino, think its the M60 although not 100%, and it has an Intel 2200BG wireless card built in. The system is using Windows XP, SP 2.
I have recently moved house, and was promised free internet by the landlord, via his wireless router.
When I search for the router, I can see it fine. He gave me a WEP key, and when I tried it, it said connected with Limited or No Connectivity. I tried to repair and nothing happened. I disabled my Firewall and nothing happened. I then tried a different WEP code, which was completely wrong, and I received the same outcome.
I guessed at this point that the WEP key was causing havoc, so the landlord disabled the WEP key, and I tried to connect to the Unsecured network. This caused the same outcome.
After some research on the net, I discovered that the router wasnt assigning an appropriate IP address.
I changed the TCP/IP settings from obtain automatic to the following:
IP: 192.168.1.37
DNS: 195.170.0.1 DNS2: 195.170.2.2
The DNS settings are those provided by the ISP , Otenet, over here in Greece.
It then said I was connected, with Excellent signal, and would send packets, but absolutely nothing being received.
I have connected to other Otenet wireless points here with absolutely no problem. The landlord said that a couple of others have had the same problem, yet 2 guys upstairs, plus the landlord and his son, can connect to the network fine - 3 of them wirelessly.
Is there something I should be doing here, and I am missing? I dont believe its a card problem, as I have used the card several times in recent weeks on different networks, and had no problems. And the fact that other people have had similar problems, coupled with the fact that others have had no problems, is leaving me absolutely stumped... can only assume its a settings problem?
Thanks in advance,
Kris
