My wireless network has been unusually slow and I have tried several remedies but nothing has worked. I was told that it might be because my connection is from a T1 line. So here is how it's set up.
It is a high-rise apartment building that already has the ethernet port on the wall that is fed by a T1 line. I can only assume is being shared by others in the building (so I am assuming that the building already has all of the necessary T1 router equipment wired into the network). I currently just have a standard D-link wireless router that is connected directly to the wall.
If I connect directly to the wall with the computer I get very good speeds but the connection creeps when I connect through the wireless router. Would there by any other hardware that I would need to have to create the optimal wireless network or could it just be the router that I have?
