I have just set up a wireless network at home between my desktop and laptop. Using a D-link adsl2+router (DSLG6424T). Everything is working as it should but I'm trying to secure it properly. The manual that came with it is thin on detail.
I have change the default login password from admin to something else (this is for access to the router via a web browser 192.168.1.1), changed the SSID name to something non descriptive.
I'm now on the WEP/WPA screen which I have selected WPA and it now says "group key interval" then has a predefined number in the corresponding box, don't know what it is ? do I need to do anything here or just leave it alone. Then is says 802.1X and then asks for a servier IP what do I put here the IP of my router or my isp dns server ? then it says the port. Then asks for a "secret" then it says PSK Hex and has a box for my input ? and under that it says PSK String and a box for me to enter something. Both these last options are radio buttons so one is only electable. Under the same config screen of the router is asks if I want to allow AP (access point" which by default it is selected.
Thats more or less what I need help with.
Thanks for any guidance.
