I am looking to install a wireless network into a property, which already has a Cat5 cable infrastructure.
I would like the wireless AP's (54g) to use the same SSID allowing for users to roam between rooms with no loss of service. Can you suggest a make/model which would fit in well to this environment? Would they operate on different channels or use the same one? There is likely to be three or four AP's.
Other than the standard Netgear / Linksys / Buffalo, what brands are used in more commercial installations (other than Cisco?)
I'm also looking for a reliable ADSL router, which has a minimum of 4 Ethernet ports, but preferably 5+, is there such a thing? If not, would I use a regular switch to increase the Ethernet capacity?
Are there any other considerations I should take into account when installing this network?
