Hello,
I am having a problem with wireless networking. Two laptops have
802.11g network cards (one is a Broadcom built-in adapter), the other has a Linksys-G 802.11g network card. The linksys doesn't have any option to select the channel in the properties, or at least any option that I see. There is no access point used. They are set to work in more or less an "ad-hoc" network. And it works quite well.The problem that comes into play is when the two laptops are used at a specific location (a physician's office). There are two other networks present, one is on channel 1 the other on channel 6. Our network favors channel 11. The connectivity is sketchy at best when it is used at this location. We cannot ask the physicans/employees to turn off or alter their network.
Is there anything we can do to make the wireless connection more stable? Since the networks are on different SSIDs and channels, they shouldn't interfere right? But they are. Is there another channel that tends not to cause interference with channels 1 and 6?
Thanks in advance for any help.
Mike McWhinney
