Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by FULK on March 2, 2005, 12:23 am
Please log in for more thread options Dear Sir, I got a Toshiba notebook Satellite 2410-702 and I have a problem with wireless network card; the operating system running on notebook is windows xp home with service pack 2. In control panel->System->Hardware->Device Manager, in "Network adapters"
there
is not the "Wireless Network Connection"; I tried to install it adding a new hardware peripherals with drivers I found on cd-rom but I couldn't manage to install it. How can I solve this problem? Thanks in advance, best regards -Fulvio- PS: the drivers for network wireless card I dowloaded from official toshiba's site are the same as the drivers I have on cd | |||||||||||||
Posted by Lucas Tam on March 2, 2005, 12:42 am
Please log in for more thread options > Dear Sir,
> I got a Toshiba notebook Satellite 2410-702 and I have a problem with > wireless > network card; the operating system running on notebook is windows xp > home with > service pack 2. > In control panel->System->Hardware->Device Manager, in "Network > adapters" there > is not the "Wireless Network Connection"; I tried to install it adding > a new hardware peripherals with drivers I found on cd-rom but I > couldn't manage to install it. > How can I solve this problem? Hi, Are you talking about your notebook's internal Mini-PCI card? Check to see if your notebook has a wireless card in the first place. If the card is not being detected... the card could be defective. I used to have bad network card and it wouldn't be detected by the OS. -- Lucas Tam (REMOVEnntp@rogers.com) Please delete "REMOVE" from the e-mail address when replying. http://members.ebay.com/aboutme/coolspot18/ | |||||||||||||
Posted by FULK on March 2, 2005, 1:13 am
> Hi,
> > Are you talking about your notebook's internal Mini-PCI card? Check to > see > if your notebook has a wireless card in the first place. > > If the card is not being detected... the card could be defective. I used > to > have bad network card and it wouldn't be detected by the OS. Yes I'm talking bout notebook's internal card (I don't know if it's PCI); I'm sure that there is! So it can be defective...is it something I can change by myself? I mean is it simply accessible and separated from mainboard or is it integrated in mainboard? Thanks in advance | |||||||||||||
Posted by Lucas Tam on March 2, 2005, 3:46 am
@twister1.libero.it: > I'm sure that there is! So it can be defective...is it something I can
> change by myself? I mean is it simply accessible and separated from > mainboard or is it integrated in mainboard? Yes, it is very easy to change. It is a Mini-PCI card - just open up the cover, and remove the card. You can even find replacement cards on eBay really cheap! -- Lucas Tam (REMOVEnntp@rogers.com) Please delete "REMOVE" from the e-mail address when replying. http://members.ebay.com/aboutme/coolspot18/ | |||||||||||||
wireless network card on notebook
Yahoo!
Windows Live
del.icio.us
digg
Netscape
