Has completely gone....
Running XP Pro with SP2
- It's not in the Network adapters tab in the device manager
- I have re-installed the driver (intel pro)
- And gone through numerous knowledge base helps..
- Wireless Zero Config. is running OK
It seems that the OS has not detected it ???
Thanks
-- Phil
