Printer / copier (Sharp) has only parallel and USB ports. Several PCs on a conventional RJ45 router, an older SMC 7704ABR. Some of these run Win98, some WinXP. No way am I going to spend a day and a half drilling holes in ancient joists and beams to run a cable. Is there a simple single-link setup that I can use to connect just that one device wirelessly, or should I replace the current router with a wireless one? Choices may be limited, as the little SMC's modem-connect capability is frequently needed when the ADSL goes down.... SUggestions? thanks / mark
- posted
17 years ago
