Hello!
I had a question, one that I hope will be pretty simple to answer. My apartment has two internet connections at this point:
- A cable connection that is run through the local university or somesuch nonsense, which has a 1gig upload/download limit but is quite fast
- A DSL wifi connection which has an no limits as far as uploads and downloads, but isn't quite as fast, and is split between room-mates.
My question is this: Is there any way to use both net connections at the same time? And if so, is there any way to specific that, say, firefox should only go through the cable, but Steam should download games through the Wifi? Thanks!
~ Matt
