Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Jeff Liebermann on February 1, 2006, 7:14 pm
Please log in for more thread options wrote: Yeah, that's the program. In all but one laptop, it didn't cause any issues. However, in the one that did, I could not get a VPN client (SafeNet) to work with it. Every time I disconnected from the VPN, the Config-Free software would notice that I had disconnected, imporoperly deduce that the wireless had been turned off, and switch the traffic to the ethernet port. Once this happened, it would not return to the wireless mode without lots of thrashing around with Wireless Zero Config. I finally got fed up with all the layers of junk piled on top of a simple wireless driver and removed both Config-Free and WZC. It worked. >
>The first time I booted these up I deleted a bunch of stuff, mostly >trialware and adware, but nothing that I thought likely to actually >interfere with the operation of the machines. I use Startup Insepctor for Windoze for that. Much better than MSCONFIG: http://www.windowsstartup.com It's free. >I'm sure there are many versions of the M45, though.
Scraped from the ToshibaDirect web pile: M45-S165 M45-S1651 M45-S169 M45-S1691 M45-S265 M45-S2651 M45-S2652 M45-S2653 M45-S269 M45-S2691 M45-S2692 M45-S2693 M45-S331 M45-S3311 M45-S351 M45-S3511 M45-S355 M45-S3551 M45-S3552 M45-S3553 M45-S359 M45-S3591 -- # Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060 # 831-336-2558 jeffl@comix.santa-cruz.ca.us # http://802.11junk.com jeffl@cruzio.com # http://www.LearnByDestroying.com AE6KS | ||||||||||||||||||||||||||||||||||||||||
Posted by tim on February 9, 2006, 10:03 am
Please log in for more thread options i think you are talking about the CONFIG FREE program ? I have a problem with connecting my laptops with a crossover cable and a switch......... my toshiba laptop always has a "limited connectivity.." and my other laptop doesnt and it can access the toshiba but the toshiba cannot access any files on the other laptop. Anyone else have anything else to add ???? I thought my toshiba laptop was faulty also .... i think toshiba knows about it as they were so sure it wasnt faulty when i rang them > DominickTotino@gmail.com hath wroth:
> > >Hi. I recently bought 2 identical laptops for me and my brother. My
> >brother lives in NY and I live in Philly. They are Toshiba Satellite > >m45's. So we bought them before Christmas and its a few days past the > >return policy for Circuit City so I've come here in hope some one had > >the same problem or someone knows what else to do. >
> The M45 series is a decent laptop and works well for a few of my > customers that have bought them. However, Toshiba installs some kind > of network configuration manager that I suspect is causing problems. I > forgot the name. I had to disable it and Wireless Zero Config before > I could get a reliable connection on one computer. However, the other > Toshiba's worked just fine with whatever they supplied. Weird. > > >The problem lies in the wireless connectivity of the laptop. The laptop
> >will initially connect wireless to my network in Philly but every 10-15 > >minutes a display comes up saying "limited or no connectivity." Now I > >originally thought it was just my laptop and I bought a defected unit > >or something. But I talked to my brother yesterday and he said the same > >thing has been happening to him. Now at my Philly house, my roommates > >use their laptops on the network and they never had this happen to > >them. Both in NY and Philly, we have Linksys 54g routers. >
> Do you have identical hardware versions of the Links WRT54G? If > they're both V5, try upgrading the firmware to the latest (1.00.6) > which fixed a similar problem. If they're not V5, try the latest for > that hardware version. > > Partial list of v5 fixes: > Firmware 1.00.6 > - Resolves issues with WAP54G repeater mode > - Resolves issues with certain PPPoE connection > - Resolves issues with SES turning back on when applying settings > - Resolves issues with WPA allowing Shared key selection > - Resolves issues with web GUI ping function > - Resolves issues with using MSN whiteboard > - Resolves issues with instability when using Bittorent > - Resolves issues with using certain ATA phone adapters > - Resolves issues with connecting to NNTP news servers > > >I've already
> >went through troubleshooting with both Linksys and Toshiba. >
> What did they suggest and what happened? In other words, what changes > and updates have you made? > > >I am
> >supposed to call Toshiba corporate today to complain and hopefully get > >a new one or something. But what still bothers me is that my brother > >and I both have the same laptops and the same problems. So with that > >said, can anyone help me out? >
> Try the laptop at a hot spot or coffee shop wireless. If that works > without a disconnect, then it's your WRT54G. Upgrade firmware if > necessary. > > -- > Jeff Liebermann jeffl@comix.santa-cruz.ca.us > 150 Felker St #D http://www.LearnByDestroying.com > Santa Cruz CA 95060 http://802.11junk.com > Skype: JeffLiebermann AE6KS 831-336-2558 | ||||||||||||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| wireless isn't working!! | January 31, 2006, 11:20 am |
| Wireless not working | February 3, 2006, 5:12 am |
| g3 wireless ics not working | November 14, 2006, 4:13 pm |
| Wireless working on one PC but not on another | November 11, 2007, 4:35 pm |
| Wireless not working | November 19, 2007, 6:25 am |
| Help! XP wireless not working | May 4, 2008, 3:43 pm |
| Wireless not working with certain sites | November 29, 2005, 5:06 pm |
| Wireless adapter not working | December 28, 2006, 12:17 pm |
| Wireless network not working | January 27, 2007, 1:42 pm |
| Wireless connection not working | March 28, 2007, 10:52 am |
| Help! wireless link between computers not working | April 3, 2005, 10:38 pm |
| wireless connection working intermittently | August 2, 2005, 9:32 pm |
| Wireless router stopped working | February 11, 2006, 12:25 pm |
| Tp-Link Wireless Router not working | August 3, 2006, 11:29 am |
| Wireless Internet Stopped Working | January 22, 2007, 1:59 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
>"Config-free" applet, the most likely candidate, hasn't caused any
>problems, except annoying notifications.
