wireless internet stops working at times
Threaded View
I have a Motorolla SB5100 Surfboard Cable modem and a Belkin Wireless G
Router.  Sometimes the wireless internet simply stops working, and to
get the internet to work, one must connect directly to the cable modem.
I think the problem lies in the cable modem though because we've had
two different routers and the same problem occurs.
The internet seems to stop working either when no one is using it, or,
so it seems, when there's an overload of information (too much being
downloaded or transmitted).
Might anyone know how I can fix this problem? Thanks very much for your
time.
View this thread: http://www.wirelessforums.org/showthread.php?t=23359
Re: wireless internet stops working at times
On Thu, 14 Jun 2007 12:44:15 -0400, mussashimits
The usual problem is DHCP (in)compatibility with the cable Internet
service.  Try updating the Belkin firmware to the latest version.  If
that doesn't help, then consider replacing the router with a different
brand and model.  (I recommend the Buffalo high-power unit.)  Or learn
to live with it.
Best regards,   FAQ for Wireless Internet: <http://Wireless.wikia.com
John Navas      FAQ for Wi-Fi:  <http://wireless.wikia.com/wiki/Wi-Fi
           Wi-Fi How To:  <http://wireless.wikia.com/wiki/Wi-Fi_HowTo
Fixes to Wi-Fi Problems:  <http://wireless.wikia.com/wiki/Wi-Fi_Fixes
Any particular model number Belkin G router?
Check if it has the latest firmware.
If the modem is working, but the wireless is not, then the problem is
probably in the wireless.  It takes 2 to tango.  What's on the other
end of the wireless link?  If it's a laptop, are you sure you're not
shutting down, going idle, running into power save, or otherwise
timing out the connection?  Also, same problem as the Belkin.  Do you
have the latest drivers?  How's the signal strength?  How's the signal
quality?
There are 4 parts to this puzzle.
1.  Cable modem
2.  Belkin Wireless
3.  RF environment (interference)
4.  Unspecified client computer.
By replacing only one part of the puzzle, you're only proving that
it's NOT the Belkin.  It could easily be your cordless phone,
microwave oven, or a list of others.  See:
<http://wireless.wikia.com/wiki/Wi-Fi#Interference
Ummmm.... if nobody is using it, how do you know it's not working?
Well, that's a possible problem.  Are you doing any peer-to-peer file
sharing?  Opening a huge number of IP sockets and streams is a well
known way of hanging a router.  See:
<http://wireless.wikia.com/wiki/Fast_Fixes_to_Wi-Fi_Problems#Wireless_router_locks_up_and_has_to_be_restarted
I usually fix things by substitution.  I think it's a fair bet that
the Motorola modem is fine.  Try connecting with a different model
laptop.  Also try borrowing a different model wireless router.  If
possible, do your testing with the client computah fairly close to the
wireless router.  That won't eliminate the effects of interference,
but will eliminate a weak signal as a possible cause.
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831-336-2558            jeffl@comix.santa-cruz.ca.us
# http://802.11junk.com jeffl@cruzio.com
# http://www.LearnByDestroying.com               AE6KS
Site Timeline
