I am trying to configure my computer to share my Internet connection with a laptop, over a Belkin wireless ad hoc network. File sharing works fine, but when I try to access the Internet it says page cannot be displayed. The IP addresses are 192.168.0.1 for the computer and
Space is limited here so I'd rather not buy anymore hardware if I can help it. The computers connect fine and file sharing is fine, I just can't understand why Internet sharing won't work, I was even running ICS on this computer recently with a crossover cable so everything should already be setup.
Listen and listen well, the XP O/S and ad-hoc wireless networking are suspect/flakey/not reliable. You all ready have problems with it. You may get it all working one day, only to turn around the next day and it not be working.
You should save yourself some grief, although, you're already on the path.
Duane is right. ICS is a problem. Some of the other software proxy solutions are not much better. Buy a wireless router. If size is an issue, there are several tiny "travel wireless routers" that are suitable. |
If you're no longer running ICS, what are you running? However, please don't answer. I don't want to troubleshoot it. Buy the wireless router.
OK I've been converted :P I didn't like the idea of the computer with the modem on it having to be turned on to be able to access the Internet on the laptop anyway!
So can anyone suggest a good cheap one? I already have a Belkin wireless card for the computer and a wireless dongle for the laptop. Is it better to have an internal modem on the router or not? my ISP provide me a modem for free.
Also what's the difference between a router, a hub, and an access point?! :-/
You should get a router that doesn't come with a modem.
Linksys and Netgear have good products
A NAT router does what's in the link wired or wireless.
You should get a packet filtering FW router that meets the specs for *What does a FW do?*. You should get one that you can use something like the
*free* Wallwacther.
This is what hubs and switches do. I don't know if wireless cards work in full duplex mode.
Routers have built in switch technology.
A wireless AP does what's in the link.
A wireless router has a wireless AP built in to it, since wire and wireless computers can be plugged into the wire/wireless AP router or a computer can use the wireless.
If the router is an all wire router, then you would get a standalone wireless AP and plug it into the wire router, so that a wireless computer can share its resources with the wire computers and access the Internet via the gateway wire router, just like the wire computers would be doing.
My ISP is Orange/Wanadoo and the modem they supply only has a USB and phone line connector on it, from what I've read I need a network connection on it to be able to use a router which doesn't have a modem built in(?).
Does any modem work with any ISP? If so, can anyone suggest a cheap wireless router with built in modem?
Well you could use a router with a built in modem and not use the modem part. Meaning don't connect it up to the phone line. But you will need a router with also an USB connection.
It depends on what standard they use. I really like 2Wire DSL modem/routers. They work in areas where others won't. On eBay they can be bought new for like 25 bucks or less. Which is a steal for all what they all do. They are built better than consumer grade too.
On Sun, 22 Oct 2006 11:28:02 -0500, "BillW50" wrote in :
What makes you think 2Wire is actually better than consumer grade? I'd rate it as better than low-end stuff, but not better than high-end stuff (e.g., Buffalo).
