I am thinking about connecting to the Internet using wireless ISP. I am currently about 2.5km away from the nearest ISP's access point. As far as I can tell, this is many times longer than any wireless card can support - normal ranges go around 100-300 meters. Am I true?
I was reading about access points, bridges, repeaters and routers.
As far as I can tell, access points and routers make additional network to which you can connect and they do not allow you to access some other available nets (like one of the mentioned ISP). Although they sometimes have additional external antenna connectors, they are only used to allow others to connect to the network they create, not to allow them to connect to ther networks.
Repeaters just prolong the range of the wireless device, but they are not good because they effectively duplicate the pollution of the signals originally sent. Wired-wireless bridges connect to the wired network on the one side and emit wireless to the other side and vice-versa. Thus, bridges are the only possible (and good) solution (beside antennas) to increase the range. Better said, they are the only solution to actively increase the signal strenght.
Are the above statements right? What are the options and what should be done?
In fact, does anyone know a good web site where all these are outlined well? I am interested in wireless beside my will to connect to the Internet. I want to learn more about the types of the devices used and how some of them could possibly help me in situations like the above.
Thanks for any help!
