I am in an area that the only high speed innternet available is wireless.
I have a Linksys WRT54GX wireless router with a desktop and 2 laptops connected wireless to it. In order to access the wireless I had to add a Linksys WET54G Bridge connected by Cat5 to the WRT54GX. Both units are currently located on the ground floor. In order to improve the line of site to the wireless provider I have to move the Bridge to the 3rd floor but there is not room there for the router as well.
Is there any way to avoid running an ethernet cable between the router and the bridge over 3 floors? Would a power line adapter work??
Thanks
Ray
