Sincerely hope you can assit with my problem. All was well until I had to re-install Windows XP Professional on my desktop. Now I cannot share files and printers even though I have connection to the internet from both computers. The setup is as follows:
O/S - Windows XP Professional SP2 on both computers Router - Linksys WRG54G, Firmware Linksys V4.21.1 Desktop is wired to the router, Laptop is wireless Internet - Connection OK from both computers Ping - Can ping the router's gateway from both computers and can ping the Desktop from Laptop but cannot ping Laptop from Desktop. Tried to ping with the laptop wired to the router but with same result Firewalls - (Norton Internet Security) disconnected on both computers
This group has helped me once before when trying to install the Linksyst router with some valauble hints and all worked fine untill I had the misfortune recently of having to totally re-install the O/S, applications and backup files. The laptop settings should be OK as I have not changed anything there. The desktop O/S reinstall was from the original XP CD setup disk (5 years old) which I then had updated via MS Windows Update
Kindest regards Mark
