No, that's not normal. My guess(tm) is that your laptop is waiting for DNS resolution and is timing out on the primary DNS server and switching to the secondary. Only the first lookup will be delayed because Windoze will remember the failed DNS lookup for about 10 minutes. Check your DNS settings and IP's. You can probably test this by opening an MSDOS window and trying to ping a web site by name and IP address. It it takes a while for the name resolution to appear, but not when pinged by IP address, there's your problem.
Try a better log viewer:
...due to their inability to forward log entries as SNMP trap the WRT54G, WRT54GS routers running their original firmware are not supported, this may look different when using modified firmware revisions (like the one provided by Sveasoft for example, if it adds support for sending SNMP Trap messages)
I'm not sure if it works with the WAP54G using Sveasoft Freya firmware.
