I just tested my wired desktop's download speed and got ~9.5MPS. I then tested my laptop with a wireless connection and got 644KPS. How is this possible? FYI, I'm using the Linksys WRK54G router.
Thanks in advance, David
Well, I determined that the placement of my modem has a huge effect on the bandwith. However, I'm still only getting half the throughput that I am on my wired systems. 802.11g should certainly provide enough headroom that I to match the bandwith I'm getting on the wired systems, right?
David
snipped-for-privacy@gmail.com wrote:
What bit rate does it say it's connecting at? Mouseover the icon on the task bar and my 802.11g setup says "Speed: 54Mbps" and "Signal strength: Excellent"
If you have encryption enabled (eg WEP or whatever) perhaps it's limited by the performance of the micro in the router? Try it with encryption turned off for a short time.
For an apples to apples comparison, use the same machine; i.e., compare wired on the *laptop* to wireless on the laptop. Also, make sure that interference isn't clobbering your wireless throughput.
On 8 Jun 2006 10:39:42 -0700, snipped-for-privacy@gmail.com wrote in :
