Hi All,
I have a Netgear DG834G v1 ADSL wireless router which has been working fine since I first bought it 2 years ago. However, recently I've notice that the wireless speed does not go above 11Mbps whereas before it wouldn't drop below 36Mbps. The router is located in the downstairs hallway but the signal varies between very low to low on a desktop PC (4m away in lounge) and low to good on my laptop (2m away in dining room). I've tried changing channels but there's no change on any of the 13 ones available. I've also upgraded the router to the latest firmware but no difference.
Having searched on Google for answers I've discovered that I'm not alone in experiencing this issue. In fact, I'm quite fortunate in getting 2 years service out of it rather than a few weeks to 12 months for some poor souls! I'm slowly resigning to the fact that the wireless component is slowly dying and may have to look at buying a replacement.
My question is whether it's feasible for the internal wireless module to be replaced/upgraded as I don't really want to trash it since everything else works fine. If not, my other option is to buy an access point for the wireless function. Any recommendations which won't cost the earth (i.e. less than £100)?
Thanks
Mehbs
