Can anyone give a couple of tips on how to deal with the above error message when pinging a wireless router? Set up a bunch of these in the past but this is causing bother for some reason.
Have set the router up with a length of CAT5, configured DHCP on it and set up a WPA key. Removed the CAT5 , rebooted and attempted to connect wirelessly.
Windows finds the access point, prompts for my password then tries to connect. It thinks for a while, then pops up 'Connected' and I get an IP address from the router (192.168.1.3). Subnet, gateway and DNS addresses are also fine if I do an "ipconfig /all" at a command prompt.
Then, I do a "ping 192.168.1.1" (just to test connectivity to the router) and I get the "Destination Host Unreachable".
Only thing I could think of was MAC address filtering but that's turned off. (Not sure if I'd get an IP from the route with that on anyway, I'd have to test it).
This is driving me batty! Anyone help?
