i had a LinkSys BEFW11S4 and now a USR8054. i had to restart the LinkSys at least once a day. i replaced it with the USR8054 and now it's several times a day. the wired connections work fine but the wirelesss will only connect after i restart it. it will work for a little while and then it stops. i am using the router for DHCP. i have a tablet PC and a Laptop connected wirelessly. I have 5.8 ghz phones. i also have 3 computers that always work wired. i am using Optimum Online with a Motorola VOIP Modem. i can connect to a neighbors WAP no problem all the time. The neighbor shows a lesser signal. The USR8054 signal is always "GOOD" or better. i have updated all the latest firmware. i truly belive that this has happened since upgrading the modem to the VOIP. i never had problems like this at my old house, now in the new house the only thing that has changed is the VOIP Motorola modem.
Any help would be appreciated.
