Acer Travelmate laptop with built-in Intel 2200GB 802.11b/g wireless network adaptor, XP Pro. Netgear ME102 802.11b Access Point, plugged into network hub.
2 more desktop machines plugged into the hub, both Win 2k, it's a 100Mb network. The Access Point is approximately 3 inches away from the laptop.I'm experiencing really bad network throughput at the laptop end, but have discovered that copying a large file from the laptop to one of the desktop machines is fast - the problem seems to be only when transmitting data TO the laptop. I get all sorts of network errors, including disconnections. Signal strength on the laptop is a full set of green bars when I look at the connection status, "excellent" when I hover over the tray icon.
I downloaded QCheck, installed it on a desktop machine and the laptop. When I run a throughput test at the laptop, sending from the laptop to a desktop machine with 100kb packet size, I get roughly 5 to 6 Mbps, which as I understand is as good as you can expect from 802.11b. However, when I run the test from a desktop machine to the laptop, I get around 30 kbps. Yep, kilobytes per second. And that's when it works, most of the time the test fails - it only works reliably when I reduce the packet size down to, say 5kb, then it shows a throughput of about 1 Mbps.
Anyone have any idea what could be causing this? I've tried all possible channel settings, and combinations of all other settings I can see.
