hi,
I'm trying to assemble a wireless network between two computers. The maximum range is 300m. All the network will do is transfer data from a GPS plus an additional 34 bits of data from one computer to another. Can anyone recommend a cheap, easy to use, off-the-shelf product? Preferably something that connects to the USB or serial port. I can only use an omni-directional antenna since one of the computers will be mobile.
thanks, Jon.
