Hello you all.
I'm having troubles since I've updated the wireless card of my Dell Inspiron
9200. I found the update in the official Dell site, dated Jan 16, 2006. I cannot connect automatically to the same wireless router: I always have to run the "repair" function. I tried having windows managing the connection and the problem is the same: is it better to have windows or the Dell utility to manage the connection? Anyway, the troubles are in both conditions. I'm wondering if I have to change some settings now, because I tried to go back to the original drive and the problem is still there. Before I d/l the update, I've never had a problem connecting even when changing location and at public hotspots. Now I have to manually connect and it always fails till I repair the connection. Any ideas?Thank you.
Steff
