Wireless card not being detected in laptop
I have a latitude D610 and a verizon wireless network card. The card used to work fine before sending it in to get reimaged. Now when I install the verizon wireless software it gets to the part where it prompts you to enter the wireless card, when I do that, nothing happens, it stays on that screen. If I reboot and enter in the card, it does not recognize the new hardware. Is there anyway I can test to make sure the pci slot is active and working properly? Thanks.
Kava
On 20 Jul 2006 05:49:07 -0700, "Kava" wrote in :
Try the card in a different computer.
John Navas
