Wireless cable modem queries
We are in a rural area in Canada (what's new...) and have Image Wireless for our high speed internet/tv provider. We have a antenna type dish they have mounted on our roof and the internet portion is connected to an ADC V251 cable modem. Everything works fine, but they have decided to up their rates AND start charging a rental fee of
12.99/mo for the modem, or purchase the equipment for 399.00.
Is there something special about this modem? Is there some other cable modem we can use?
Thanks for any info Marilyn
weowncaseih
You really should ask Image/YourLink if they allow customer supplied hardware. They might, depending on the frequency and type of equipment required. However, I suspect that you will rapidly approach the $400 cost if you purchase your own hardware and do your own installation. Judging by your description, my guess(tm) is that it's an ordinary MDS/MMDS or wireless DOCSIS modem.
Also see:
What does the end-user equipment look like? The equipment varies depending on the frequency of the signal, but generally there is a transceiver/antenna on the roof connected to the inside of the house via cable to a cable modem.
What frequency does your wireless equipment use? We have several frequencies, depending on the customer's location. Our equipment is based on 2.4GHz, 2.6GHz, 3.5GHz, as well as 5.7GHz radio technology. It is 802.11b or "Wi-Fi" compliant.
Jeff Liebermann
