Go to this website and check out thier configuration with a cantenna.
- Vote on answer
- posted
18 years ago
I need to WiFi enable my PS2 (which only has ethernet connectivity), since a PC with ICS and my router are both too far away to lay cable.
As wirelss bridges like Linksys' WET54G are nearly as expensive as WiFi routers, like the WRT54G, can/should I use the latter as this has more functionality?
Many thanks for any assistance.
news.ntlworld.com cried out
if they are too far awawy to lay ethernet (328foot max) then they are most likely WAAY too far for wifi
just for laughs linksys game adapters
why dont u go for a wap54g? its a gaming adapter from linksys which would suit ur needs. check out the linksys website for more details
Rosco hath wroth:
Just a minor note on cable. I have several installations running about 900-1000ft of either 10base2 Cheapernet coax or CAT5 that work just fine. The limiting factors are:
I can expound more on this if your interested. There's also some stuff I've scribbled on the topic in the archives.
[snip]
No, it's just not practical to lay the cable
You could use router/AP as a "client", I suppose. It would be somewhat "bulky" and you'd have to disable much of it's functionality (especially DHCP). Unless you plan on setting up an additional network down the road, probably make more sense to just go with an adapter.
I'm using a DWL-810+ wireless-ethernet adapter for both my PS2 and Dreamcast (with the DC BBA, obviously). Works great, even with a cheap little hub in front of it allowing both the PS2 and DC to be connected (not supported by DLink, but it works). DWL-810+'s can be found for like $25 to $30. In addition to the PS2/DC one, I have another one and considering picking up yet another as they work great for piddly stuff (consoles) on my 802.11b "junk" network.
Cheers, Eric
Just to add: never had any latency problems with them being used for consoles even though they aren't so-called "game adapters". I've even used them with a network printer and they worked great.
Thanks for this info. :-)
